TwinTurbo.NET: Nissan 300ZX forum - Is this with a aftermarket crank pulley? Engine warmed up?
Evan_Wright (Ca)
on May 28, 2013 at 4:37 PM
Can't set timing correctly
posted by Glooj
on May 28, 2013 at 12:09 PM
Sometimes the mark on aftermarket pulleys are incorrectly placed. Also, you need to wait until its fully warmed up before setting timing.
Glooj
12:09:57 05/28/13
Is this with a aftermarket crank pulley? Engine warmed up? -
Evan_Wright (Ca)
16:37:05 05/28/13
Yes it can be timing belt issue, to verify it...
puchy
10:02:00 05/30/13
Re: Yes it can be timing belt issue, to verify it...
Glooj
23:43:48 05/30/13
Also; stock crank pulley (n/m)
Glooj
23:45:14 05/30/13
Have you tried placing a spark plug wire between the end
Evan_Wright (Ca)
09:28:04 05/31/13
